Panasonic KX-TD7896 Cordless Phone Logo
A
Anonymous Posted on Mar 25, 2014
Kx-gc212 ring setting
Answer too fast
Here is a link where you can download the user manual for free which will explain how to set the phone to answer after a certain number of rings. Just go to the link its already set up just click on the download link.
http://www.retrevo.com/s/Panasonic-KX-TC1743W-Telephones-review-manual/id/2914bh651/t/1-2/
I have panasonic kt tga 101s phones that goes to voice mail after just 3 rings . How do I expand it to 5 rings?
KX-TGA101S is an add-on handset for a Panasonic KX-TG1000 series cordless phone system. One of the models that is compatible with the handset is the KX-TG1032S. You can find the manual for the phone system on the product page here: https://shop.panasonic.com/support-only/KX-TG1032S.html . Assuming that you do not have voice mail from your telephone provider, you can change the number of rings from the Answering Device Settings Menu.
Start with the phone system in standby (no incoming or outgoing calls) mode. Press Menu and use the up/down keys to navigate to Answering Device. Press OK to enter the sub-menu. Navigate to Settings and press OK. Navigate to Ring Count and press OK. Use the up/down arrows to choose a new number of rings. Press OK to save and press Off to exit the menu system. Note: if the ring count is set to Toll Saver mode, the answering system will pick up on the second ring if there are new messages. It will pick up the incoming call on the fourth ring if there are no new messages.
See page 31 of the manual for the KX-TG1032 for this information. See page 23 for the way to navigate through the menu and a list of the menu tree items. The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg1031_en_om.pdf .
I hope this helps.
Panasonic kx-tg6821al when someone rings it goes straight to answering machine. The phone does not ring it just goes straight to answering machine
Likely the machine answer option is set to AUTO. This may be change to any number of rings from 2 - 9.
To set number of rings;
1. [MENU] #211
2. Select number of rings with up/down key.
3. [OK]
4. [OFF/PWR]
Download a copy of the manual for more detailed instruction from...
https://www.manualslib.com/manual/817662/Panasonic-Kx-Tg6821al.html
KX-T7710
The KX-T7710 isn't an answering machine. The ring count is controlled by the answering machine or voicemail system connected to the phone line. Could you tell us the make and model?
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
4helpful
KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
2helpful
Set number of rings
First press the menu button then scroll up or down to "initial setting" and press the select button. then select the set answering option then select the number of rings option now you can select the number of rings by scrolling up ^ or down. or you could just press the number on the keypad. Once you have selected the amount of rings you want press SAVE, then press off and your all set.
Set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
How to change ring tone of kx-t7730
sir please i want to when call my consol i'm not there i picup phon our telephone set plz suggest
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
