If this is a Bosch dishwasher, the E15 error indicates water in the base of the unit. You need to unplug the dishwasher and pull it out (if it is an under-counter unit) carefully. Empty the water from the base. Sometimes tipping the unit so that the base is tilted 45 degrees from the floor will help the water flow out. Make sure that the entire base is dry.
Replace the dishwasher under the cabinet (if needed) and plug it back in. If the error repeats at the next cycle, you need to determine where the dishwasher is leaking. It could be the outlet hose, the pump or the tub. Replace the bad part. If the dishwasher is under warranty, contact Bosch.
I hope this helps.
(if you recently had a flood either under the kitchen sink or an overflow at that sink, you just need to dry the dishwasher base.)
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
The first thing I would do is to locate source of the leak. Look carefully at faucet when it is on and see if you have any water leaking from areator and running back down the underside of spout and leaking around base of faucet, also see if you have any leaks around handle. If the leak is from the areator you can just replace it and not have to remove the faucet. when you check under sink on faucet supply lines make sure they aren't leaking at that point. I would use paper towels or rags to wipe everything dry under faucet and let it set for 1/2 hour then check again. If it.s still dry run some water and use both hot and cold water seperatly,checking underside in between. If you determine that leak is coming from top side and leaking thru. Shut off water supply valves if available if not shut off supply to house, make sure water is off before proceeding. Disconnect supply lines from faucet,Remove retaing nuts on either side of base,and remove washers. Remove faucet and check for any obvious faults. If you think it was leaking around base get a small tub of plumbers putty. Most hardware stores stock it. Remove a golf ball sized portion or larger and knead in your hands until it is warm and pliable. Press into place in faucet base. Continue doing this until it's full. Reinstall plastic or rubber base gasket and put faucet back in place Put washers and retaing nuts back on a tighten till snug. Center faucet where you want it and tighten securely. Scrape off excess putty with knife point and wipe with paper towels till clean. Hook up supply lines and turn water back on. Check for leaks and good luck. Thank you
This indicates water in the base, there is a polystyrene float that operates a cut off switch if water leaks into the base, this could be caused by a leaking pipe connection, or simply by water getting by the door seal and eventually having enough volume in the base te operte the float switch, try tilting the machine backwards if water comes out of the basethen this should cure the problem, but if it recurs fairley quickly you should have the hose connections checked for tightness, can be accessed from the base.
the dishwasher should be isolated from the supply first base tray is secured by 6 screws, the float switch is attached to the base so care should be taken when removing the base tray
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
