Question about Casio Forester FT500WV-3BV Wrist Watch
I need to change the date
It has the wrong date
    New Friend:
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Posted on Jan 11, 2016
SOURCE:
Problem with day/date changes! My casio edifice
follow these instructions off the manual below if you set the watch in wrong sequens it wont change at 12 oclock
http://support.casio.com/en/manual/009/qw5125.pdfhttp://support.casio.com/en/manual/009/qw5125.pdf
Sep 27, 2013 | Watches
Watch date changes between 1:45 am and 2:00 am
turn it 12 hours forwards or 12 hours backwards that will correct it to the right date change
Jan 12, 2013 | Watches
Date is wrong on neff watch
Keep pressing mode until you get to where you get to edit the time and press the "light" button until there's a big number and that's the month and keep pressing the light button and you can edit the date and what day it is
Dec 16, 2012 | Neff Flava Watch Watches
I have a Tissot Automatic PR 516 from the early 70s. Time is kept well. Date moves forward correctly but it is the wrong date. I am unable to turn back the date. I am able to turn back the day. Any...
The crown wheel (winder) should have 3 positions, (1) the normal winding position (3) fully out; at this position the watch stops and the time can be adjusted.
(2) This position is between the 1 & 2 and is used to adjust the day and date. If you wish to change the date by winding the crown backwards or forwards.
Since watches can very a little, if turning the crown when in position 2 the date does not change, pull the crown to position 3 and turn the hands until you pass the midnight position, when the date will change and then re-set the time. If you wish to advance the time more than one day, when it changes, wind the crown backwards past the midnight position and then wind it forwards again. Repeat until the correct date is showing and then re-set the time. The exact distance you need to turn the crown to change the date will have to be found by experimenting!
Feb 06, 2011 | Watches
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
How do I change the "day of the week" on my Tommy Bahama 1072 watch?
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 16, 2010 | Watches
Change day on dial
Pull out the crown to the first click- the watch is in day-date setting mode. Turn the crown one way- the date will change. Turn the crown another way- the day will change.
Rate me, please.
Mar 21, 2009 | Guess Collection Textured Dial Watch
I can't set the date on my new citizen's eco drive BM8080-59A. I don't know if I'm doing it wrong or if the date setting function is broken. I have tried to change the date by pulling the winder to the...
Yes that is ok its right by pulling the crown winder in the mid level or half level,that is for calendar date.To check if function is ok or broken,just pull full the crown and set the time,see if the calendar date is changing or moving.Then if moving then its ok,the next step you do set is the calendar date,by pulling the crown half pull,then turn the crown counterclockwise for date and for the day turn clockwise.Feel free to post whatever the result of the setting...
Hope it may helps you;
Regards,
VOTIT
Sep 23, 2008 | Citizen Watches
Rolex Day and date changing at 7.00pm instead of 12.00 Please Help. Am I doing something wrong... Thanks Deb
you are not doing anything wrong. How long have you had this watch ? is this something that just started ?It sounds Like the hands are missaligned, the only way to fix this is to send it to a qualified watchmaker to realign the hands and pressure test the watch. Feel free to email me if you need anty more help. donald@finewatchmaking.com
May 20, 2007 | Rolex Day-Date President 118238 Wristwatch
Date changes at the wrong time.
The hands must be adjusted.fairly easy fix
Sep 27, 2006 | Baume Et Mercier Baume & Mercier Capeland...
Casio Forester FT500WV-3BV Wrist Watch Logo
455 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Casio Watch Expert? Answer questions, earn points and help others
