Question about RIM Blackberry Curve 8900 Smartphone
App error 532
When i switch on my phone its shows app error 532....how can i slove it
    Habit-Forming:
    New Friend:
  • 42 Answers
Read the MANUAL and then operate have a good day .. thanks Vijaya
Posted on Apr 11, 2014
SOURCE:
SOURCE: how to correct app error 532 for blackberry curve
i have the same problem, what did you do to fix it?
Posted on Aug 06, 2010
SOURCE: I switched off my my phone, when I switched on
There's pretty much no diagnosing those -- they are the equivalent of the random errors in Windows for which tracing the root cause is fruitless. Basically, these are the last out in the programming code -- some event occurred for which there is no handler in the code. The fix is a code update that handles the event...but, again, knowing what the event is is pretty much impossible. So, there are a few things to try:
Sometimes, the code simply becomes corrupt and needs to be refreshed -- just like a reboot:
  • Anytime random strange behavior or sluggishness creeps in, the first thing to do is a battery pop reboot. With power ON, remove the back cover and pull out the battery. Wait about a minute then replace the battery and cover. Power up and wait patiently through the long reboot -- ~5 minutes. See if things have returned to good operation. Like all computing devices, BB's suffer from memory leaks and such...with a hard reboot being the best cure (but remember it may wipe out your data to factory settings).
There might be an updated code set from the carrier -- check them via this portal:
The toughest possible cause is a badly behaving app. To find it, there are a couple of options. One is to see if you can read the log file:
Go to the home screen. Hold down the alt key and type 'lglg'. (You will not see anything while you type).This will bring up the log file. Scroll down (probably many pages) untill you see a line that says 'uncaught execption'. Click on this line. The name of the app will be in the info.
The other method is to remove apps one at a time, waiting a while in between (I usually recommend a week), until the problem ceases...thereby discovering the offending app.
Posted on Nov 16, 2010
  • 438 Answers
SOURCE: my bb curve 8520 have
HI ANTHONYBADOU lkisten you hae an apllications software crash on your blackberry. yOU WILL NEED TO USE YOUR COMPUTER AND THE BLACKBERRY DESKTOP MANAGER. First thing you nedd to do is make sure that your computer or laptop are in good workking order. You will need to follow the directions on the desktop to the letter. Now plug the blackberry into your computer it will ask you if you want to backup all your information yes. If the computer can not see your bb this will not work. it means that the software is corrupt. Once the computer see the bb it will ask you if you want to m\backup and restore the data yes. Ler the ciomputer bacup and reinstall all yout information. This whole process from start to finish could take anywhere 1-2 hours. All your apllications need to be reinstall on your blackberry. Ok i hope I help you.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Nov 26, 2010
cellphonez99
  • 132 Answers
download a BB desktop manager ,install it and then connect your phone to the pc via the cable ,let the pc install the drivers o the phone be patient , your desktop manager will recognize your phone , there is one option name update device ,click on that and follow the instructions ur phone will be updated online and your prob will be solved , if u still need assistance mail me at cellphonez99@gmail.com
Posted on Dec 03, 2010
  • 7 Answers
SOURCE: my phone keeps restarting and
You need to reinstall the phones OS, to do this you will need a computer with the Blackberry desktop software installed.
Below is a link to a site that has detailed instructions on how to do it, its a bit involved but take it step by step and it will work (I have done this at work quite a few times)
http://supportforums.blackberry.com/t5/BlackBerry-Device-Software/How-To-Reload-Your-Operating-System/td-p/228990
Posted on Feb 23, 2011
What is sc 532 on aficio mp c2500 and what if the machine shows your that your fuser settings error
"Fusing duplex motor locked" check the fusing duplex gear box or clean if not so you can change duplex motor.
Sep 01, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
My blackberry display app error 532 what must i do
Try removing the battery and then replace it back after about 1 minute to reset your phone.
Nov 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
Why does my blackberry 8520 show(app error 532) when its switch on
Hi there.
That error message generally shows up when the is an application that is installed on your phone that has gotten corrupted or isn't compatible with your device. the first suggestion that RIM suggests is to do a reset. This is done by pulling your battery out for afew seconds and putting it back in. If that doesn't help and you can still use your phone try deleting the most recently installed apps and resetting after each uninstall. If you cannot use your phone then you will have to reset it to factory default and reload the software. There are many methods to do this. Some however and easier than others.
Sep 09, 2011 | RIM BlackBerry Curve 8520 Smartphone
How to slove BlackBerry Curve 8520 Smartphone app error 523 reset problems
Please follow this link and it will help you fix your phone problem.
FOLLOW ME
Good luck...
Aug 21, 2011 | RIM BlackBerry Curve 8520 Smartphone
Keeps sayin app error 532 reset then when i reset it< it does the same again time after time
Hi! May we know the phone model and brand of your phone? In this case, you might have installed an application that can't be supported by your phone.
Jun 28, 2011 | Cell Phones
My phone keeps restarting and says app error 532 or somthing
Feb 23, 2011 | RIM BlackBerry Bold 9700 Smartphone
How to correct app error 532 for blackberry curve 8520... I saw an uncaught error message for a second then it went away and now my blackberry curve 8520 has a white screen saying app error 523? then...
Dec 03, 2010 | RIM BlackBerry Curve 8520 Smartphone
When i turn on my blackberry bold 9700,it shows white screen with application error 532 and reset. when i press reset button it turns on and off automatically.plz help me
Hi hafiz7779 ok you need to load the blackberry desktop manager onto yout computer or laptop and reload your phones apps back on to it. The desktop manager is going to save all your information and restore yout apps. plug the phone into the computer or laptop. It will ask you to backup your information and restore say yes. You wan the phone the way it was before the crash . fyi you need to blue disc that came with the phone or you will have to go on blackberry dot. if you don't know where it is. this will et your phone back for you.
Dec 03, 2010 | RIM BlackBerry Bold 9700 Smartphone
When my phone restarts the hour-glass icon pops up
Mostly is software problem reinstall software & to be contineu with your phone.
Sep 23, 2009 | RIM BlackBerry 8700g Cellular Phone
RIM Blackberry Curve 8900 Smartphone Logo
42 people viewed this question
Top RIM Cell Phones Experts
RONALD CARTER JR
gggg
Ekse
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
