Forgot bios password
You can call or go to the store you got it from and ask them if they would possibly know. after all they might find your solution
Hi , follow the link video , i Hope That can help u
How to remove BIOS password for Acer Aspire 57 Series
SOURCE: reset bios password or remove
The laptop password cannot be reset by removing the battery and there is no jumper for the CMOS or bios reset. You must go to Acer to obtain the master password as laptop computers have NVRAM (non-volatile RAM) that retains the password forever as an anti-theft protection. Steve Medley
SOURCE: Bios password on acer extensa 4620
ok on all desktops there is a jumper on the motherboard conecting 2 out of three pins and on the motherboard it says psswd. power off and unplug it then remove the door on the back where the ram goes ill bet thats where ull find it. take the jumper off and put it on the other pins. boot it up and password should be dissabled go int bios and make sure. u can leave it like this or turn off and replace the jumper. hope this helps.
P.S. if the jumper isnot by the ram check behind any other doors the laptop might have
SOURCE: Bios of laptop Acer Aspirinhe 9410 (reset the bios)
Hi...
To reset the bios you need to open your laptop you can see there a jumper which is there is a small name (CLRSCR means clear cmos)beside the jumper you need to get it and turn on your laptop with in 5 seconds then turn it off, after that you reinsert the jumper, then turn on your computer and see if there is a bios password. "good luck"
Regards
PCmania
SOURCE: please i have a bios password on my acer
dont wory.. enter 3 time wrong password u will get a code send me that code... ill send u master password:)
