Huawei U8800-51 Impulse 4G AT&T Android Smartphone Logo
A
Anonymous Posted on Mar 24, 2014
Trying to change apn for att Impulse 4G but cant find MMS_APN
Phone with at&t
I need the apn settings for my at&t zte life wireless
You chould contact your cellular provider and ask them for it.
or you could try these:
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: [email protected]
Password: cingular1
Server: <Leave in Blank>
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
Taken from here:
https://apn-settings.com/us/att-apn-settings/
Good Afternoon..... I cant receive or send pictures what is the APN code for SVP G13 watch phone
An Access Point Name (APN) is the name of a gateway between a GPRS, 3G or 4G mobile network and another computer network, frequently the public Internet. A mobile device making a data connection must be configured with an APN to present to the carrier.
For AT&T
Programming non AT devices with the correct APN and MMS data settings AT...
For Tmobile.
Mobile apn settings Step by Step Configuration
I cannot receive any text messages that contain a picture
There are a few things to do that may fix your issue:
1. Delete text messages off of your phone (especially if you have hundreds of texts to one recipient)
2. Go to settings in your "messager" app and reset setting to default.
3. Make sure your APN settings are correct:
Go to "Settings"
Select "More networks"
Select "APN"
Edit your currently used apn...
APN: wap.cingular
Proxy: none
Port: none
Username and password are blank
Server: none
Mmsc: http://mmsc.cingular.com
Mms proxy: wireless.cingular.com
Mms port: 80
Mcc: 310
Mnc: 410
Authentication type: none
APN type: default
2answers
Why wont my mms work?
Make sure your 4g is on and make sure that your data plan is for 4g
Straighttalk settings for blu phone
try this one
had the problem going through forums trying to find the settings that work for my phone but to no success but I finally figured it out and I'm posting it on here just in case some one else has my same problem.
I had to create two separate APN's one for internet and one for MMS. Settings are as follows:
Internet:
Name: Straight Talk Internet
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User Name: Not Set
Password: Not Set
Server: Not Set
MMSC: Not Set
MMS Proxy: Not Set
MMS Port: Not Set
MCC: 310
MNC: 410
Authentication Type: PAP or CHAP
APN Type: Internet
APN Protocol: IPv4
Bearer: Unspecified
MMS
Name: Straight Talk MMS
APN: att.mvno
Proxy: Not Set
Port: Not Set
User Name: Not Set
Password: Not Set
Server: Not Set
MMS Proxy: 66.209.11.33
MMS Port: 80
MCC: 310
MNC: 410
APN Type: Internet+MMS
APN Protocol: IPv4
Bearer: Unspecified
Do not forget to create two separate APN's!!!!!
goodluck
Need apn settings for at&t straight talk Samsung galaxy discover.model sgh730g at&t4.0.1.1 when first got phone it showed. 4g.phone it blacked out called straight talk they had me changed the apn settings...
Straight Talk AT&T APN Name ATT 4G LTE APN tfdata Proxy proxy.mobile.att.net Port Username Password Server MMSC http://mmsc.mobile.att.net MMS Proxy proxy.mobile.att.net MMS Port MCC MNC Authentication Type PAP APN Type default,mms,supl,hipri APN Protocol IPv4
Sep 11, 2017 • Cell Phones
Cant recieve picture messages
Make sure your APN settings match.
APN: tfdata
Port: 80
MMSC: http://mms-tf.net
MMS proxy: mms3.tracfone.com
MMS port: 80
21helpful
3answers
I need the apn setting for the HTC Inspire picture messaging for t-mobile, thanks!
here you go i have my htc inspire 4g working perfect now it connects to the internet and sends mms fine
APN:epc.tmobile.com
Proxy:216.155.165.050
Prot:8080
Username:none
Password:**** (i typed in 4 stars) :p
Server:* (i typed in 1 star)
MMSC:http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy:261.155.165.050
MMS Port:8080
MMS protocol: Wap 2.0
MCC:310
MNC:260
Authentication:NONE (Make sure you dont leave blank put NONE)
APN type:default,admin,dum,mms
enjoy
Nokia 6085 on att won't send or receive mms/multimedia messages
For the normal at&t apn settings, or also called at&t wap settings, these are the values you should use
APN: wap.cingular
Password: cingular1
MMS port: 80
MCC: 310
MNC: 410
at&t apn settings 4Gdetails: If you have a 4G phone (e.g. iPhone 5, Galaxy S4, HTC one, etc) you should try using these at&t apn settings 4G. They run faster and more stable connections.
APN: phone
Username: <Leave in Blank>
Password: <Leave in Blank>
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
APN type: default,supl,mms,hipri
Bearer: leave it to the Default one at apn settings Step by Step Configuration
Top Huawei Cell Phones Experts
NOEL
NOEL
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
