Question about Samsung PN Televison & Video
Pink band issue pn58c8000 - PN Samsung Televison & Video
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
Dec 27, 2013 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Need to rerplace Samsung pn58c8000 mainboard
It is not an easy work as you assumes. In most cases, after replacement to this board, a firmware update might be necessary. If you're sound in electronics, check the site linked here for more details. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 05, 2013 | Samsung PN58C8000 TV
My Samsung PN58C8000 plasma tv has red banding on white backgrounds. I see this a problem with this tv. How do I repair this and how much will it cost? The tv is out of warranty.
I have the exact same TV with the exact same problem. The issue is called diffusion and is not repairable. A Samsung repair tech can adjust the voltage settings but this will only work for a few weeks and cost a little more than $100. If you call Samsung they may be willing to issue you a new panel gratis (they did for me) but you will have to pay labor for the swap (about $400). If you do this the new panel will start to act up just like the old one so I would advise against it. Samsung will also claim that this is not a common problem which isn't true - especially for the 58" models which are seeing many extended warranty claims (which I didn't purchase).Best advice is to deal with it until you can't take it anymore and then buy a new TV but avoid Samsung in general and especially their plasmas. That is the route I am taking. And bashing Samsung for bilking me out of $400 6 months ago to replace a defective product with an equally defective one and then saying so sorry but you're now on your own.
Apr 02, 2013 | Samsung LE Televison & Video
Pink horizontal lines on samsung plasma tc when white background
I have this same tv and have the same problem, anytime there is a white background there is this pinkinsh tint in the middle of the screen, easily seen during those Apple commercials.
Aug 13, 2012 | Samsung 3D Plasma TV PN58C8000YFXZA...
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
I have a pn58c8000 and sometimes the sound has problems. I can never predict when the problem will happen. The sound will become very high pitched and everyone talks in high squeaky voices like only the...
make v reset press the exit button on remote for more than 10 sec message reset will appear select yes tv will turn of turn tv back on and select home use this could repaire your problem
Mar 26, 2011 | Samsung PN58C8000 TV
BG1301 Casio watch replacement band
Go to "casio.com" and click on "support".
Although they don't say so directly, their repair section imply that they can replace straps.
Jul 20, 2010 | Casio BG1301-4V Pink Baby-G Watch with...
Ricoh CL7000 Pink bands
Hi there you have the magenta drum cleaning fault. You will have to replace the Magenta PCU (Photo Conductor Unit) 99.5% sure
Thanks J
Nov 15, 2006 | Ricoh CL7000 DT2 Laser Printer
Televison & Video Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
