Question about SanDisk Sansa c240 MP3 Player
Change battery on scandisk 240
Change battery
    Novelist:
    Scholar:
  • 99 Answers
THo now this is out of date and if you can even find a battery anymore to open the back slides in the direction of the the hookup.battery can be a bit stubborn to remove will need to pry it up slightly being careful the casing doesn't get removed.
Posted on Oct 15, 2014
SOURCE:
My laptop keeps saying that i need to backup because my c drive needs repair what do i do
ScanDisk is a Windows utility which detects and corrects errors. Windows XP introduced a significant change to ScanDisk. The utility was integrated into the operating system. You should run ScanDisk whenever you notice a hard drive is not performing well and also on a regular basis to fix errors as soon as they happen.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions
  1. 1 Open "My Computer" in Windows XP.
  2. 2 Find the icon for the hard drive you want to run ScanDisk on. You can run ScanDisk on the system's primary hard drive and also on any secondary hard drives or external hard drives. Right-click on the icon for the hard drive and select "Properties."
  3. 3 Choose the "Tools" tab from the hard drive properties window. The ScanDisk utility can be activated from the Error-checking box at the top of the Tools tab. To begin, click the "Check Now" button.
  4. 4 Note the two check boxes displayed. You will want to choose the "Automatically Fix File System Errors" box. This will perform a basic fast scan of the drive, which will take only a few minutes.
  5. 5 Put a check in the "Scan for and Attempt Recovery of Bad Sectors" box for a more thorough scan. With this checked, Windows XP will take 10 hours or longer to run ScanDisk depending on the size of your hard drive. Run this if you have noticed a problem with the hard drive's performance. For regular checks, run the basic check most of the time and the longer check only occasionally.
  6. 6 Hit the "Start" button to start ScanDisk.
  7. 7 Wait for Windows XP to finish running ScanDisk and view the report. ScanDisk will tell you what errors it found and fixed. Click the "Close" button when are finished viewing the report.
Read more: How to Run ScanDisk in Windows XP ' eHow.com http://www.ehow.com/how_2126653_run-scandisk-windows-xp.html#ixzz1BXNDbxHd
Jan 20, 2011 | Lifetime Toshiba Satellite P505S8980...
On subzero morning few days ago my 93 240 had trouble starting. tried about 7-8 times and finally it would not even attempt to turn over. The dash lights go dim as if its drawing power but nothing is...
take the battery to a garage an ask them to do a load test on your battery, you can have 12 volts but the battery cant deliver the amps you need.
Jan 13, 2011 | 1993 Volvo 240
I don't know how to delete all the music from my sansa scandisk m 240 device
the fastest way to do this is to connect it to your computer go into the computer screen right click on the device and choose format..
Jul 12, 2010 | SanDisk Sansa m240 MP3 Player
Volvo 240se
On older types 240 there was some kind of antitheft system connected with the steering lock. Try to route a lead from the battery to the ignition coil and se if it starts.
I drove a 240 with a separate ignition switch all through high school.
Apr 05, 2010 | 1991 Volvo 240
Scandisk language change
On the main menu go to Settings then to System Settings. Scroll down to Language and set desired.
Jul 14, 2009 | SanDisk Sansa Fuze MP3 Player
ScanDisk Sansa C150- ScanDisk Logo blinking and can't do anything
my mp3 player don't work properly..
when i plug mp3 players in my pc it work properly... after that when i unplug it my mp3 player doesnot work upto now.
when i switch on that it will display only scandisk logo.. then that it will not work.
then to switch off that i should take out battery.. you have any solution..
after that the pc also don't detect that player
May 10, 2008 | SanDisk Sansa c150 MP3 Player
Camera card not holding pics
Van D UK is right. It seems suspiciously like a memory card corruption problem - maybe caused by the combination of the red battery light coming on and the act of taking the picture.
If you remove the scandisk card (camera off) and use a card reader to view the contents on a computer, you maybe can see if the file structure on the scandisk makes sense.
Presumably you have the camera user manual. This might help.
There might be some info about how to set up a new scandisk card. You might be able to rescue all the photos you have already on the existing scandisk card. I suggest you rescue them as a priority if you can. I suggest too that, in future, you download as a matter of habit all your photos (regardless) onto a computer. Having rescued as much as you can you can either re-format the existing scandisk card using the camera (if you can) or buy yourself another scandisk card.
I have had similar problems with my Sony camera and card. Try and get the correct card for your camera. I got some cards simlar to a Sony card but in the end I could only use one of them in the camera. The other had to do duty as file storers/transferers.
Mar 17, 2008 | SanDisk Memory Media
Olympus VN-240 is dead
clean out the battery compartment with alcohol
or else repair
Sep 01, 2007 | Olympus VN-240 Digital Voice Recorder
SanDisk Sansa c240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
