Televison & Video Logo
A
Anonymous Posted on Mar 24, 2014
Autoscan digital channels
Cant access digital
2answers
Can't highlight or select digital channels to autoscan on hitachi 51f59a
It sounds like you're experiencing an issue with your Hitachi 51F59A TV not allowing you to select or highlight digital channels for autoscan. Here are a few things you can try to resolve the issue:
  1. Check the TV's settings: Make sure the TV is set to the correct input (such as "TV" or "antenna") and that the channel search or autoscan feature is turned on. Consult the TV's manual or the on-screen menu for instructions on how to access these settings.
  2. Check the TV's connection: Make sure the TV is properly connected to a digital antenna or cable box. Also, check that the cables are securely connected and not damaged.
  3. Check for a firmware update: Sometimes a firmware update can resolve issues like this. Check the TV's manual or the manufacturer's website for instructions on how to check for and install firmware updates.
  4. Try a factory reset: If the above steps don't work, you can try performing a factory reset on the TV. This will restore the TV to its original settings and may resolve any issues with the channel search or autoscan feature. Consult the TV's manual or the on-screen menu for instructions on how to perform a factory reset.
  5. Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
How do i autoscan channels?
On my tv I just press autoscan and it automatically scans all the channels it will receive on whatever connection you have.
Why doesn't autoscan doesn't detect digital channels?
make sure cable is selected in set up instead of antennae. Also is it a digital tuner in the TV or did your TV provider recently make it so you can't get their channels without a digital adapter.
TV will not scroll through the channels. I have to enter each channel manually
If you have a cable box from the cable company you may have to autoscan the channels first look in the instruction book for autoscan channels
How to autoscan
It is either under channel program or channel scan and in some models channel setting
The problem with the tv is that it is no longer able to be turned on. i have tried many different outlets and that is clearly not the problem. also, the power system that came with the tv still has a green...
Hello
Connect the TV to external antenna or cable and do the following ot autoscan channels. If it autoscans, and doesn't store any stations in its memory, the memory IC has damaged and should be replaced with same type and number. Wait till autoscan completes and see whether the first channel receve will comes displayed or not. It will take some time to complete. the procedure is:
From Menu Press Vol [+/-] then Channel [UP/DOWN] buttons to find CHANNEL AUTOSCAN.
Press Volume [+/-] button, channels will be scaned automatically. OK
My set top box will no longer pick up certain channels such as itv and channel 4 stations !!
My set top box has setup menu, channels, autoscan to scan for channels. They changed some of the channels here after the original switch to digital, and a fresh autoscan was needed to again find the channels that moved. See if your box has autoscan for channels, and do it.
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
No signal after autoscan for channels
Tv stations main channel is an addition of 1 (04-1) but can have up to 5 stations (4-1, 4-2,4-3,4-4,4-5). They may not have anymore then one, it is their choice. PBS usually has 2 or 3 channels
Top Jensen Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
