If the message light on the Telstra cordless handset 1 is flashing, indicating a new message, but the message light on handset 2 does not flash even when it's on the cradle, there are a few troubleshooting steps you can try:
Check message notification settings: Make sure that the message notification settings on both handsets are properly configured. Refer to the user manual or the settings menu on the handsets to adjust the message notification settings. Ensure that the notification is enabled for both handsets.
Reset the handsets: Try resetting both handsets to their default settings. This can be done by removing the batteries from the handsets, unplugging the base station, and leaving them disconnected for a few minutes. Then, reinsert the batteries and plug in the base station. Allow the handsets to reconnect to the base and check if the message light on both handsets functions properly.
Check the base station: Ensure that the base station is functioning correctly. Check if the base station is properly connected to the telephone line and power source. If possible, try connecting handset 2 to the base station that handset 1 is connected to and see if the message light functions on that base station. This will help determine if the issue is with the base station or the handset itself.
Contact Telstra support: If the issue persists after trying the above steps, it may be best to contact Telstra support directly for further assistance. They will have specific knowledge of their product and can provide more detailed troubleshooting steps or advise on any potential repairs or replacements that may be necessary.
Remember to refer to the user manual for your specific Telstra cordless model for more detailed instructions on troubleshooting and operating the handset.
Have you tried resetting the light? On either the end of the dash on the drivers side or the end of the dash on the passenger side there is a panel that covers the fuse block. You'll need to have the door open to access it. Once you remove the cover you should see a button that says reset. Turn the key to the run position and press the button. The change oil message should flash, press the button again and the low tire message should flash, press and hold the button until the low tire light turns off. Sometime there will also be an audible series of beeps when it resets.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
I may have already posted a solution for you from another location. But if not heres what I said. If you also have voice messaging with your phone company, you might have voice messages stored with them. If so you need to access it with your password to clear them. To find out if you do have voice messaging, call your phone company and they can let you know and reset your password if so. The phone companys voice messaging system sends out a signal that would cause youe phone to think it still has a message waiting.
error message Oxd0620230, hp 5610 all-in-one, i have tried all the
power resets. the cartridge stalls when the code comes up but it don't
always stall in the same position. lights flash...
Vehicles Without Message Center
To reset the system, press and hold the odometer reset button and wait for the "TIRE PRESSURE SET" light to illuminate. Continue to press the button for 3 seconds, then release. After 3 seconds, the low tire pressure warning lamp will flash 3 times, indicating that the low tire warning system reset procedure is complete.
Vehicles With Message Center
To reset the system, press and hold the SETUP button and wait for the message center to display "REST FOR SYSTEM CHECK". Then press the RESET button and wait for the message center to display "HOLD RESET TO RELEARN". Press and hold the RESET button for 3 seconds. The message "HOLD RESET TO RELEARN" and the low tire warning lamp will flash 3 times, indicating the reset procedure is complete.
If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
