Panasonic Lumix DMC-ZS3 Digital Camera Logo
J
Jonathan Posted on Mar 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic lumix dmc-zs3 display colors not showing
The camera still takes pictures but the display screen only shows yellow, blue, and green colors.
freddy0707
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Mar 30, 2014
freddy0707
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
8512
Points
12
If still under warranty ask for a replacement, other wise get use to it
  • Official Brand Answer 350 Answers
  • Posted on Mar 25, 2014
Panasonic
Level 0:
Answers
350
Questions
0
Helped
84481
Points
487
We recommend you enter the camera's menu and try using the reset procedure, in the setup menu, available here: http://service.us.panasonic.com/OPERMANPDF/DMCZS1.PDF#page=24
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on May 31, 2010
SOURCE: My Panasonic Lumix® DMC-ZS3 will not focus
Try checking your settings or menu for a vibration sensor or changing the focus. You might also be using the wrong setting, like indoor, when you're at the beach. You can also change the quality of the pictures and if you are taking still photography or movement.
Anonymous
  • 178 Answers
  • Posted on Jun 03, 2010
SOURCE: My LED screen for my Panasonic Lumix DMC-FS15 has broken.
the best answer.. very carefully...
becarefull with replacing your screen, if you don't have the right precision tools and other equipment you might further damage your camera
Free quote for this repair at:http://www.teleplancamerarepair.com/manufacturer/repair-camera-model-problems.asp?mo=680
Anonymous
  • 84 Answers
  • Posted on Jun 18, 2010
SOURCE: Broken LCD on Lumix dmc zs3
Here it is: http://www.ownta.com/panasonic-lumix-dmc-zs3-digital-camera-repairing-lcd-display-screen-replacement.html
Anonymous
  • 6831 Answers
  • Posted on Oct 07, 2010
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Anonymous
  • Posted on Nov 23, 2010
SOURCE: I dropped my Lumix DSC ZS3 and now there are
november 23 2010
i dropped my panasonic dmc-zs3 and now there are vertical lines on the view finder. also, these lines appear after taking a photo or video.
can this be repaired?
cost?
thank you in advance ;-(
Is there a way to correct color issues on my lumix dmc-fh25
Set the camera's white balance to match the lighting. Most indoor lighting has a yellowish cast to it, while by default cameras are set for sunlight.
Panasonic Lumix DMC-ZS3 When I focus the camera
hi
you have a problem wtih the photo shutter of camera
you must replace it
the cost of it is to high you better replace the camera
My Panasonic Lumix® DMC-ZS3 will not focus properly. All pictures are blurry. Anyone know what might be the problem?
november 23 2010
cost?
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
