kawasaki PVS1965 Portable DVD Player Logo
j
joanne pirnie Posted on Mar 24, 2014
We hook it up light's come on but dvd does not spin
Kawasaki pvs1965 mobile dsvd player with duel 6.5 screens
5 Related Answers
Anonymous
  • Posted on Aug 18, 2007
SOURCE: Kawasaki pvs1965
You can order replacement parts from the following web site. We had accidentally cut one of our player to screen cables and I ordered two through this site. Had them within 2 weeks, no problems. http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Anonymous
  • 1067 Answers
  • Posted on Feb 02, 2008
u wann put pc on tv use vga cables have tv that ready for it s video out on video cards wont do it
Templarius
Davor Krstevski
  • 86 Answers
  • Posted on May 26, 2008
SOURCE: Not recognizing disc
Thry to clean laser lens DO that very carefull
rich694
  • 5 Answers
  • Posted on Jun 02, 2009
SOURCE: kawasaki PVS1965 Portable DVD Player cables
I found the newer support site.
http://www.venturer.com seems like the manufacturer, but they don't list the PVS1965. They list a PVS1960 which seems to be an older model.
To order the cables, I went to http://www.venturer.com and then that clicked me through to http://www.1800customersupport.com/products.aspx?view=270&p=5&sc=6&sn=Mobile%20DVD%20Systems&pn=Car%20Entertainment
Anonymous
  • 563 Answers
  • Posted on Aug 04, 2009
SOURCE: No valid disc message displayed. Disc is spinning.
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
I HAVE A BLUE SCREEN. WHEN YOU PUT A DVD IN, DVD SPINS BUT NO PICTURE JUST A BLUE SCREEN.
Hi eme i suggest you change the lense or check your connection it might be you did not plug the cords connecting to tv in order for it to show. From deborah.
3helpful
Same
Reader or "laser" lens probably just needs to be cleaned. Do this w/ rubbing alchohol and Q-tip.
disconnect power b4 you do this.
Portable dvd player Kawasaki PVS 1965
check the connections and connector of the blue screen one.
Kawasaki pvs1965
Portable DVD Player
make sure your player is set to the video output, and not set for internal use.
1helpful
3answers
Kawasaki pvs1965
3answers
Kawasaki dvd screen damaged
Visit the official customer service website for this product, http://1800customersupport.com/kawasaki, or call them at 1-877-252-6873. They should be able to sell you one. Target also sells an item that should work. It's called the Kawasaki AVM678 or Audiovox AVM6781, and designed to work specifically with the PVS1965 or PVS1965S. I believe it's $79.99, but only available in their stores, in the portable DVD section of the electronics department.
6helpful
2answers
Kawasaki PVS1965 Portable DVD Player cables
I finally found the customer support website for Kawasaki electronic products, including the PBS1965:
Top kawasaki Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
