Trying to change a path in a CCR on a Nortel Norstar Flash phone. I disable the CCR, when I go to change the message under OTHR>CCR>ADMIN and enter the CCR tree number, it enables the tree again. What is going on? Why is is re-enabling the Tree before I can record a new message so that the new message will be saved?
AA
AA/Grtg/Grtg/1 = Thank you for calling ABC
AA/Grtg/Grtg/2 = Thank you for calling ABC we are now closed
AA/Table/1/Morn = Grtg 1
AA/Table/1/After = Grtg 1
AA/Table/1/Even = Grtg 2
CCR
CCR Path 0 = If you know your parties ext plz enter it now
for list of staff press 1
PATH 1 = MENU, record list of Staff
You need to disable the CCR Tree in Table before you can make changes. DISABLE to disable or 1 to enable.
You should get a tech in to do this and train you how. 1 hour should do it.
Choose Other, CCR, ADMIN, Enter 1 for CCR tree one and when the option for "Path" appears press 0 and you will have the option to record. I believe there is an option for "More" which you select and play the greeting if not you can choose rec and the option to play the current greeting will be on the screen.
This is the most complicated part of the Norstar voice mail system and requires a tech or fully trained admin at site.
It is called CCR Custom Called Routing. You need to record "thank you for calling ABC" under AA/GTG/GTG/1 You then need to build a CCR tree and record the rwst of the greeting under Path 0. Path 1 , 2 etc is where you do the pointing. There is too much to mention here that needs to be done. Norstar System Coordinator guide (for any version) is your friend as well but a 2 hour service call is well worth the headache.
Incomplete tree means that one of the selections has not been programmed with what to do. A tree has to be disabled to make changes in the tables. Once changes have been made you can enable it again in the tables that use it.
The programming of the individual paths is done in CCR programming. First you have to disable the CCR tree to change the programming This is accomplished by entering feature983>password>AA>table>Gtng table:1 (might be a different table but 1 is the most common)>press either ok or next til you see CCR tree: 1 then press CHNG and disable. Next press the * key til you return to the main menu ( mbox AA OTHR) and press the OTHR soft key. Press the CCR soft key >admin>and the tree number(probably 1). At this point it asks for a "path" number. A path is the action when a certain digit is pressed (1 for Dale..) Enter path 1> transfer>int>and 223 (which is dales extension number) and ok.Continue with the remainder of the paths until done.Next press the END soft key and the SAVE>SAVE as tree 1 YES soft keys. Lastly don't forget to re-enable the CCR programming AA>table>GTNG table:1>>>>> CCR tree: disable. CHNG>and the number 1. Press the Rls key when finished.
The feature your looking for is custom call routing(CCR). If your using 4 digit DN's then you probably have larger office environment which I'm not sure that a CCR tree will handle efficently. To build your CCR tree, enter into voicemail admin programming, press the OTHR soft key, then the CCR soft key ehn the ADMIN key enter in a CCR tree number, then press build At this point you would enter in the number of the path you want to build and what it will do. ex. path 1 means when I press 1 on the dialpad I want it to call Mary's extension(transfer, internal, ext 2221) When your finished building your paths you'll need to save your tree.then you'll need to enable the CCR tree under AA,TABLE, Grtg Table:1, then press next til you see CCR tree: none. Press the CHNG soft key then 1 on the dialpad and ok. That will enable CCR tree 1 to work in greeting table 1. Theres a large section dedicated to building and changing CCR trees in the Nortel voicemail manuals so don't be discouraged if you don't get it on your first try. good luck
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
