CD player works fine, tuner received stations but have no sound from boxes Reset system a couple of times with no resolds
SOURCE: Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
SOURCE: Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
SOURCE: Subwoofer in my car works only on tuner
I had the same problem. most radios have a power antenna wire and an amp turn on wire it sounds like your amps are being turned on by the power ant wire that loses power when you put a cd in try swapping the blue with blue and white wire this should solve it
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
SOURCE: sony cdx ca650x has no audio output from tuner, CD is OK
Tuner might be defective , check to see if tuning voltage varies
