When printing the non image area of the plate is picking up ink and transfering to the blanket. You can't physically see the ink on the plate but after a few impressions you can see it on the blanket.It usually isn't a huge issue until you start running 2 colors and then you get ink migration from one side to the other
SOURCE: I have banding background on film.
Try http://www.xante.com/support/pm4/manuals/PM4/troubleshooting.pdf
Or you can call:
Technical Support
& Service
Tel: (251) 473-4920
Fax: (251) 473-4980
Toll Free: (800) 926-8393
Monday - Friday
7 AM - 6 PM
CST
SOURCE: Platemaker 4 (image quality problem)
Read this epson page
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_2.htm
There might be something of use for you.
SOURCE: image quality
Not my area of expertise,but maybe a change
in ink cartridge or material is in order
SOURCE: THIS MACHINE, ILLUMINA, IS THE
Hi, I am Steve
this is the best place to start , taken from the Xante Support site
"This is caused when arcing occurs across the surface of the toner drum. To correct this, pull the toner cartridge from the printer and check the metal contacts on the left side of the printer. Make sure that they are not laying flat. On the right side, following the guide for the toner you will notice another contact, which is the ground. Make sure that it is not pushed in to where it does not make contact with the toner. Gently pull this out to ensure contact.
The Bias Transfer Roller (BTR) behind the toner drum is black and spongy. It has two beige handles. Make sure that you can push this down and it springs back into place. Check both ends to ensure each springs back. You may need to take this roller out and clean it. Make sure that you get it seated properly."
If we start twith this we can troubleshoot further if it does not solve your problem.
