I put in a new memory card and transferred data to it, now my ringtones has changed and I cant play my music, it says unavailable
SOURCE: Transfer music from computer to phone
When you put the SD card into your laptop, it should show-up as a hard drive (one of your drive letters on a Windows machine).
Copy or drag your music files from your computer's hard drive to the "music" folder (it might be named "audio", I can't recall) on the SD card. This folder should be there if the card was previously in your phone. Once the files are copied there, they should play on the phone.
If you still have problems, try reducing the bit rate on the music files. I'm not sure how high of a bit rate this phone can handle.
So, for example, if your music is encoded at 256kbps, try reducing them down to 192kbps. I'm not 100% on this, but it's worth trying.
Good Luck!
SOURCE: Transfering Music from PC to Samsung Envy SD card
yes you can using wrong file format. you can insert music on MP3 format type support to the mobile.
SOURCE: can't get music or ringtones on my samsung SCH-r500.
what folder are u putting the music into on the phone?
SOURCE: i cant format a memory card for my samsung gravity
dude download avest anti virues free from google and scan ur memory card then format it m sure it will work.
