I have a LG Front Load washing machine and water is leaking from the top of the drum unit and running down the side when fresh water is being introduced through the attached water lines. The water lines are not leaking and we've pulled the back panel to detect this particular leak. Any advice would be greatly appreciated.
SOURCE: LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
SOURCE: My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
SOURCE: LG wm2101hw 4.0 cu.ft front load washer is leaking
same problem. LG stated I am using too much soap. Cant be because it still does it with no soap. Also have issues with spinning on bed comforter and also drum will not drain. I can wring out a 16oz of water from a cotton shirt sitting in the bottom of drum when completed. Floor is flooded and I am **********. Bought in April 2010 and have had 4 techs out to look at it, but there is no problem. Biggest waste of 600 I ever spent.
Hi
The water leaking on floor can be a serious issue as this may cause the inside
parts to malfunction or in some cases rusting of the body. To check where
exactly it is leaking; inspect the leak while it is running. After the cycle is
complete quickly turn off the power, lie down the machine on left/right side
and check from where the water is leaking. If it is the hose or drain pump then
check whether hose is connected firmly and is not cut. If it not the hose/pump
inspect if the leak is on the drum corner or anywhere back of the
drum. However, if it is leaking from the circumference then it is due to
transmission seal. To replace the transmission seal you'll need to disassemble
the washer and the drum assembly.
Please post back in case of any issues. Hope
this helps...
Daniel
I found the problem when I removed the top cover of the washing machine and the boot seal at the top has a split in it. Will try and find a replacement. Thanks
