I can`t to install the driver
Though you do not specify WHY you cannot install the driver, probable reasons, among many, are:
1) You need administration rights before you can install software. If this is the case, call your employer's support centre, if applicable, or log onto the machine using the Admin log on. If you're the person who installed or used the machine from first use, you are the Admin. If this is the case, then this is NOT the reason.
2) Your install CD may be deffective (remember, you did not say why you cannot install; I'm guessing).
3) You may need to uninstall the existing driver before you install the new one. This is how you do it:
Assuming you're running Vista, click on an empty area of your desktop and right click with the mouse. From the ensuing menu, select and click Personalize. Next, select Display Settings and then Advanced... Next, go to Monitor->Driver tab. Click on either the Update Driver or Unistall. The first one will ask you for the location of the driver. Point the utility program to your installation CD and continue the installation.
If you chose Uninstall, then close all windows and running programs, and restart your machine by switching power off and turning it back on.
After Windows has started, repeat the installation steps from your CD. It should work, provided the disc is also Ok.
