John Deere 7800 23637 Logo
Posted on Mar 24, 2014
Can I install a mulching blade on a walk behind JS26 mower without compromising the integrity of the mower?
Model name: JS26; MFG model 7800574
Matthew Walter
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Nov 02, 2018
Matthew Walter
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
5637
Points
30
I myself would contact people that built it and ask a tech that knows everything about that machine also ask and see if they sell an attachment because if they do than i'm sure it would work better for you than putting one on that could void warranties and damage your machine
Troy Bilt self propelled walk behind...grass goes everywhere!!
Mine works,great,take bag off and it will mulch it and look like it's being bagged up.Is your grass knee high?Do you have it low enough?Here's your manual,read the part on grass catcher and see if your doing something wrong,make sure grass door is open.Check your blade to make sure they didn't put it on upside down.The cut part should be facing out. http://pdf.lowes.com/operatingguides/043033566280_oper.pdf
Jul 21, 2017 • Troy Garden
Can I convert my John deere propelled non mulching lawn mower into a mulching lawn mower?
look at your nearest Tractor Supply, Wal-Mart, or Sears... find mulching blade for your size mower, swap the blades be sure the blade has the right center pattern
How do you put a mulching blade on a troy bilt 21 inch walk behind lawn mower
remove the center bolt from under the machine put a block of wood against the blade to hold it from turning on you
Apr 13, 2012 • Garden
I have a model 944-604810 riding lawn mower and find that it leaves a trail of cut grass even though it is equipped with a mulching blade and a new mulching cover. It would appear that the grass is not...
yes that is most likely the cause of it, also, you have to cut more often when mulching, and the higher the cutting deck, the more likely the grass will blow out without getting mulched enough. More than likely, the blades are dull, and/or the grass is too high, or possibly even wet if it is high.
1helpful
Have a murray model 226111X92B 22
go to this website http://www.ereplacementparts.com/murray-226111x92b-2234-lawn-mower-parts-c-17887_17944_19048.html and find the part your looking for. i went to the site and found what you are looking for..good luck
Mulching blade replacement for Toro GTS 6HP
goto toro website and use model of machine to get blade model and use blade model in google to get prices and then order them
Jul 06, 2009 • Garden
2helpful
Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Jun 02, 2009 • Garden
5answers
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
[email protected]
Top John Deere Equestrian Experts
Imagdrider
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a John Deere Equestrian Expert? Answer questions, earn points and help others
