Rear brake noise after brake replacement
probably a dumb question, but if there is a backing plate, did you make sure it isnt bent and hitting the rotor? you never want to sand new rotors, although i dont think it would cause this concern. i would suggest lightly scuffing up the brake pads. this will eliminate any noise caused by the contact of the rotors and pads. if it goes away then you know its a problem with the pads/rotors.
scoring of only the inside rotors would make me think that possibly the caliper slides are frozen up. make sure they move quite freely on the slides. it is not uncommon for brake pads to score rotors though.
but brake noises at low speeds that dont' change when applying light brake pressure are usually some sort of metal or something contacting the rotor.
