Our Brother MFC 7340 will not send or receive faxes. It always gives a report saying "Line Busy"
Sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Try downloading user manual: Brother mfc 7340 manual Download Free Manuals
SOURCE: I cannot send nor receive faxes.
Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
SOURCE: Brother mfc-5840cn
press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
SOURCE: brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
SOURCE: Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
SOURCE: I have a Brother MFC-8460N and I can't send or
How can I downloading driver for canon laserbase mf5650 for System x64-based computer please?
The fax machine make a light static crackle when connected to the phone line and dialing and sending. The fax is normally on a dedicated line but we have teated it on another line also with the same result. Will not send or receive.
To make sure there is nothing wrong with the telephone line,try plugging a phone into the line and see if calls can be made.If yes then the modem is the problem.you might find a used one on ebay.
