Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
A
Anonymous Posted on Mar 23, 2014
How do we replace the bulb on a 73 inch tv bulb
How do I replace the bulb
I still get a blank screen after replacing DLP chip and lamp. Any suggestions. Can you use cleaning duster to clean?
is the lamp turning on, if not then there may be a problem with the inverter board. or the bulb is faulty, bulbs can become faulty in transit.
73 inch tv speakers are off how do you turn them on
Go to menu and click on sound on this click to see if speakers are turned on if not click on if that doesnt work try the try the return to factory settings..
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
The remote sensor is bad on my 73 inch mitsubishi wd73736 tv. Where is it located and where can i get a replacement?
Remote sensor is always on front of set behind a clear or tinted small lens and inside it usually is on a circuit board .
1helpful
Replacement lenticular screen for vs6041 60 inch mitsh
we recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
