From: Leah [email protected] I wanted to make looped videos for my cat to watch while I am running errands like the ones I have bought. I thought maybe you needed special sorts of dvds made just for looping? please also reply to my email address? ciao and thanks!
Hi Leah
There are two options that might work for you. The commercial DVDs you buy that loop, have a setting enabled when they are created that causes the player to loop. A lot of the programs that you use to make dvds at home have the ability to enable this setting as well. It depends on what program you use so check the help files or do a search for Make Loop DVD With ( Your Software ). Some players also have a playback option called looping, continuous play, or even store demo mode that would allow you to run any DVD in a loop mode.
SOURCE: Windows won't start
you may want to try to re-install window but use whats called a non desturctive install, when you put the disk in and asks if you want to format the drive or leave the file system intact ......leave the file system intact this should keep all you data however you will need to re-install any programs you have put on the computer other than a standard install of windows......
It would appear that the boot loader (mbr) has become corrupted as you said you tried all the options in the safe boot menu............let me know how you get on
SOURCE: Linspire 6.0 deleted & missing emails
Here is the link to the mainboard :
http://www.asus.com/products.aspx?l1=3&l2=11&l3=498&model=1574&modelmenu=2
SOURCE: download drivers motherboad,audio drivers download,board vga down
We only post here not to email.
here's the link youneed to select operating system.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Mark
SOURCE: Video and sound hesitation playing DVDs or short video clips
The problem was screen resolution was set to high. When I set down 1024/768, the problem stopped.
Thanks for the answer.
Frank
SOURCE: i just bought a p4b-mx motherboard to replace my old one.
Just the same things happened to me recently than I find out that one of the leg of my CPU was broken then I have changed the CPU with the other one, same sound as you had mentioned were stopped..Try this one
But still I have other trouble due to I cannot fix the the Cpu frequency Switch
My Cpu p4 1700 mhz
Help needed..
