I am experienced seamstress/quilter and this is I am beginning to think a problem with the mechanics of the machine. I have repeatedly done the tension settings and this locking spasm continues. I get no response from the Janome company.
SOURCE: Janome 6600 tension
Lint trapped in the tension dials is the most likely cause
If you are using a standard tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks.......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
SOURCE: Janome 134D Overlocker
Set you differential at 1.0 and your loopers at about 3-4 the needle thread tensions are usually around 5 to 6.
I would also suggest that you place four different color threads on machine to make it easier to adjust all. Now if you are using only 3 threads the same applies.
Also------patience.
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin.
Most sewing machines with rotary (drop in) bobbins don't have an easily
accessible bobbin tension screw, which means your fabric is usually
slightly puckered. Fiddling with only the upper tension helps very
little. This frustrates me to no end for sewing long curtains, clothing
side seams, etc. Wrong tension causes them to hang with puckers, making
them look awful. With the Hello Kitty 3/4 size Janome, there is a screw
on the bobbin case which allows you to adjust for every thread diameter
perfectly. Always a perfect stitch, if you take the time to adjust this
screw.
To adjust the bobbin for a perfect tension, load the bobbin into
the bobbin case and thread it through the guide. Holding only the
thread between two or three fingers, let the bobbin case dangle below.
This will be slightly difficult, because the bobbin will want to fall
out of the case. Don't worry, just don't move it around too much and it
will stay in long enough for this test. If the metal bobbin case slowly
drops lower, unwinding thread as it goes, the thread is too loose.
Tighten the screw on the side of the bobbin case a little (about a
quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a
gentle tug, lifting up fairly quickly. If it doesn't release a couple
of inches of thread, it's too tight, loosen the screw. You know the
tension is perfect when a quick, light tug of the thread releases a
couple of inches of thread.
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
