Lorus Rare Walt Disney Mickey Mouse Quartz Wrist Watch Y481 1720 Leather Band Logo
A
Anonymous Posted on Mar 22, 2014
What battery does this use - Lorus Rare Walt Disney Mickey Mouse Quartz Wrist Watch Y481 1720 Leather Band
Donna Cornett
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 13, 2016
Donna Cornett
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
364
Points
What battery fits the mickey mouse watch y481-1720?
1helpful
2answers
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • 0helpful
    2answers
    I want to put 4 batteries together 4x 12v 7AH. and how many volts and AH would that be.
    It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
    If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
    If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
    2answers
    I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
    I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
    Attributes Battery BCI # : 75
    Battery CA @ 32 Degrees F : 775
    Battery CCA @ 0 Degrees F : 630
    Battery Height : 7 1/4"
    Battery Length : 9 3/4"
    Battery Posts Type : Side Post
    Battery Reserve Capacity : 90
    Battery Voltage : 12 volt
    Battery Weight : 33 lbs.
    Battery Width : 7"
    Wet or Dry : Wet
    A lead acid battery with the fallowing specs
    group 75
    Battery Width : 7"
    Wet or Dry : Wet
    Battery Width : 7"
    Wet or Dry : Wet
    Battery BCI # : 75
    Battery Width : 7"
    Wet or Dry : Wet
    1helpful
    2answers
    How about this Pavilion dv8000 Battery for HP Laptop Battery?
    You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
    http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
    http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
    3answers
    Nikon D40x indicate battary low
    Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
    3answers
    Choosing batteries
    Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
    Top Lorus Home Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Lorus Home Expert? Answer questions, earn points and help others
