Error 60 is connection to the CD player interrupted.
There is no supply voltage present for the decoder board or the CD player.
Check that all of the cables to the decoder board are in good condition and connected correctly and securely.
Error 60 means connection to cxd player interupted,no supply voltage present for decoder board ,check cables to decoder board and fuses
IF YOU NEED THE MANUAL AND SERVICE PROGRAMME EMAIL ME I WILL SEND THEM ON A DVD DISC [email protected]
How can you check voltage to the decoder board? How can I access the decoder board? Where is it located?
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
