HP PSC 2175 All-In-One InkJet Printer Logo
A
Anonymous Posted on Mar 22, 2014
Is the hp2175 capable of being wireless?
I am using a mac can I use the hp2175 wireless with a mac?
Hampi Hemp
Level 3:
  • HP Master 706 Answers
  • Posted on Dec 17, 2014
Hampi Hemp
HP Master
Level 3:
Answers
706
Questions
0
Helped
238549
Points
6294
2answers
HP DESKJET D1360 HOW TO SET UP WIRELESSLY USING MAC
Are you trying to use MAC filtering. You would just need the MAC from the network setup screen and add it to your router/firewall.
If you are using a Mac (Apple) computer you would, providing you have a wireless adapter connected to Mac, just go into "System Preferences" and use the wizard under "Print & Scan". Make sure the networking on the printer is in on the same as your Mac.
Is this printer wireless so I can use with my laptop?
Canon PIXMA MP530 is not wireless capable.it can only be installed over usb connection. OS Compatibility : Windows® 7, Windows® XP/2000/Me/98 and Mac OS® X version 10.2.8 to 10.5.x
2helpful
I have an old Power Mac G5 WITHOUT wireless capability. Just bought a Belkin F7D2101 Surf & Share Wireless USB Adapter. But I can't seem to find a driver for Mac. Is there a solution?
Belkin surf is not compatible with any versions of Mac osX...Take it back to stores...
The list of belkin adapters that supports MAC OSX are...
buy any of the following models...
f5d9050 v4
f5d6050 v2
f5d5055 v1 & v2
Does it have wireless capability?
> does it have wireless capability?
Probably not, as delivered from the factory.
Connect a USB-wireless adapter, to add a wireless interface.
Example: http://www.dlink.com/category/productcategories/?cid=3
WANT TO USE A CONTROLLER WITH MACBOOK PRO
Inspect the mac book pro for connection ports capable stylos, keyboards, or mouses as substite control devices. Howver, wireless blutoth allows to acquire wireless device connection within vicinity. Adjust the computers network capabilities to enable foreign wireless devices or if an specific device is required turnin on the device may be deteced by computer wireless.
2helpful
NOOK is not capable of responding to the Linksys router
The tech was correct about that matter. However you can configure the MAC to always allow the device.
  1. Find your MAC for NOOK. I think you have already did.
  2. Go to Setting and then to the Second Page to find it.
  • Configuring MAC
  • Wireless MAC Filter. To filter wireless users by MAC Address, either permitting or blocking access, click Enable.
  • If you do not wish to filter users by MAC Address, select Disable.
  • Prevent. Clicking this button will block wireless access by MAC Address.
  • Permit Only. Clicking this button will allow wireless access by MAC Address.
  • Edit MAC Address Filter List. Clicking this button will open the MAC Address Filter List. On this screen, you can list users, by MAC Address, to whom you wish to provide or block access. For easy reference, click the Wireless
  • Client MAC List button to display a list of network users by MAC Address.
  • Change these settings as described here and click the Save Settings button to apply your changes or Cancel Changes to cancel your changes.
Please rate the answer as well. Feel free to contact if you have any other problems or if this solution didn't solve the issue.
Thanks for contacting Fixya!
Will not print
The Simple Network Configuration capabilities of Mac OS® X can only find devices in the local network segment. If your Macintosh® and devices are not in the same network segment or are connected via a router, you cannot use the Simple Network Configuration capabilities of Mac OS® X.
In these cases, I recommend you use IP printing.
I have a Belkin router. All of our PC's are working including my netbook. The only computer not working is my husbands MAC. Any solutions?
Check that the wireless adapter is correctly installed -- correct device-drivers loaded.
Check that the wireless adapter is not "disabled" (a slider switch?)
Try the wireless capabilities of the Mac at a "hot-spot" (Starbucks? Public Library?) to see if it can connect to *ANY* wireless network.
Run the Apple Software Updater, to ensure that OS X is properly updated.
Check that the Mac is connecting to the correct SSID, with the correct password/passphrase.
Airport settings in Mac leopard
Make sure your ADSL router has wireless capability or wireless function. Verify that from your Internet Provider. If your ADSL router doesn't have wireless function, you need to buy a separate wireless router then cascade it to your ADSL router, from there your airport must be working fine.
Stopped printing PDFs and Web pages
those your printer support wireless printing? if not try to check if it is bluetooth capable
k24674
Grand Canyon Tech
Grand Canyon Tech
