Freezing
2 part answer! depending on whether your DS is freezing because of a game or without a game
1. if freezing when you insert a game it is most likely to be because of dirty pins in the game slot. to sort this try to scrub the pins clean with VERY FINE sand paper (clean gently to avoid bending pins they are reasonably delicate!!)
2. if freezing well into a game or without a game in the console, this can be caused by water damage to the motherboard.
if you can take off the back casing off the console you will be able to see the motherboard, look over it for white marks. if any are found gentley clean with circitboard cleaner and then dried immediatly! DO NOT USE ANYTHING ELSE other than cleaning fluids designed for electronic equipment or you will cause further "water damage".
