I suggest you can approach Unlocking4u.com and specify the country,locked network of ZTE Z222.Based on the availability you can get the permanent unlock service along with free instructions.
Connect your device to your PC by means of its USB cable, navigate to the fikle you wish to transfer to the device, open up anopther session of windows explorer and locate your device, navigate thriough itsd file structure until you find the file folder where you want to store the data,then simply copy and paste.
have a good program like File Commander pre instyalledon your device, thios will help you navigate fikles, folders, photosd etc. SDMaid is also a very good app as well.
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
I had the same problem I have a ZTE USB modem & when I connect it with mac it never show up...so I googled ZTE for Mac & I found a driver update & update for connection manager . After installing them the modem work as charm
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
