i have got a maxim alarm clock and i don't know how to use it.I think i threw the instructions away would you be able to tell me how to set the time please.
Hello there.
You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen.
2 Touch [Clock Settings].
3 Touch the desired date display format, then touch [t].
The clock settings screen appears.
4 Touch each item, then set its numeric value by touching v/V.
5 Touch [OK].
To cancel the clock setting
Touch [Cancel] or [BACK] in step 5.
Sincerely,
Steve TM
I dont know what deck you have but you can try this. Turn off the deck by holding the source butten then hold the function butten you will be able to turn on and off the warn for the alarm along with the clock.
Hi there, For the manual for this unit head to this page http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally, Hope this helps Cheers Steve
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
