Sky remote ode for hitachi 40HXT16Uj
0104 0107 0110 0119 0126 0127 0150 0152 0161. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
SOURCE: Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the
Sky Remote
3) Hold down the select and red
buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the
Sky Remote again
5) Enter the 4 digit code for
your make of TV
6) The LED should blink twice,
if not recheck the 4 digit code used and go back to 1
7) Press the standby button on
the Sky Remote (The TV should go to standby)
8) Press select to store this
setting
If the TV does not go into
standby press the TV button then the standby button, then TV then standby,
keep repeating this until successful. This will scan the codes used for a
particular make of TV.
SOURCE: technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
SOURCE: Sky remote code for tv model JO47 Baird
These are your codes,0117,137,221,371,218,220,236,100...Here is a link for directions, www.digitalsat.co.uk/skyremotecodes. hope this helps..
253 384 377 173 606 469 591 509 065 071 072 064 060 133 137 224 245 255 191 391 576 544 501 222 100 371 226 178 304 103 549 497 527 584 334 604 123 536
OK.
