Usually can use remote to lower windows and open sunroof but suddenly stopped working. Also not working with key in door. Any advice?
SOURCE: Sliding power doors will not open
Just had the same problem with my '05 van. I put the Master Switch in the off position. I pulled fuse #7 on the driver side sub panel, located just above the engine hood release. I then disconnected the neg. terminal on the battery. I manually opened the pass. side slider and closed it.
I reconnected the battery and replaced fuse #7. I put the master door switch in the on position. I activated the auto door switch, and it worked.
SOURCE: Can not open any door using the key or remote control.
Hmm, probably a dead battery. The problem with those locks is that they are electrically actuated, not mechanically unlocked. Thats why the key turns easily. If you turn and hold it to the unlock position, and the battery is okay, the windows will roll down. If they dont, then its the batt. Call a mechanic.
SOURCE: Honda Odyssey doors
I read about this issue while I was looking for a fix to mine. Try the following:
Remove fuse #13 for 30 seconds or more from the passenger side fusebox. This will reset the door and the clock.
OR
1.) Disable the power door switch on the left dashboard.
2.) Remove the power door fuses located under the front passenger leg area.
3.) Manually open and close both sliding doors.
4.) Restore the power door fuses located under the front passenger leg area.
5.) Enable the power door switch on the left dashboard.
6.) Try opening the sliding doors.
http://www.topix.com/forum/autos/honda-odyssey/TD1QRDMAQ28J8EDA0
SOURCE: 2003 Honda Pilot Door locks not working
may be a relay switch, or a faulty wire on the right side behind the glove box
SOURCE: Honda Odyssey 2005 sliding doors won't open, beep 3 times
If you click once your remote control ,will open just driver side doors.To unlock all of them have to press twice , and then sliders.
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Central locking not working?
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
