Televison & Video Logo
Carmen Reis Posted on Mar 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Grundig p40 540 text
Boa tare a minha tv grundig p40-540 text pede-me um codigo
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 22, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003343
Points
237762
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Minha impressora esta dando esse codigo de error 6950 , a minha e Taskalfa 5551.
https://translate.google.ca/?sl=auto&tl=en&text=Minha%20impressora%20esta%20dando%20esse%20codigo%20de%20erro%206950%20%2C%20a%20minha%20e%20taskalfa%205551.%0ANao%20sei%20ooque%20fazer%20ela%20ta%20com%20esse%20codigo%20de%20erro%206950&op=translate
6950 Description: Fuser IH PWB communication error No response is received in 30 ms since a command is sent to IHCPU. A checksum error is detected 10 times in succession. Remedy: Power source PWB: 1. Confirm that the wiring connector is firmly connected and, if necessary, connect the connector all the way in. Power source PWB (YC9) and Feed PWB 1(YC4) Power source PWB (YC3) and Fuser IH PWB (YC1) 2. If the wiring is disco
1helpful
2answers
MINHA PLACA GV -650/800 (S) CONGELA IMAGEM DEPOIS DE ALGUNS MINUTOS DE Ligado.
Voce pode ter alguns virus e malware.
Comece o seu PC e prima F8 varias vezes ate que o menu de inicializacao vem a tona. Em seguida, selecione "Modo Seguro com Rede". Agora se alguns ou todos os programas gratuitos abaixo.
Baixe, instale e execute o Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
Quando Instalacao escolher a versao nao-profissional.
O download, descompacte, instale e execute TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Baixe, instale e execute Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
Se voce tiver um programa anti-virus desatualizado depois baixar, instalar e executar o Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Certifique-se de selecionar TODOS os "categorias de ameacas" quando voce instalar ou configurar o Avira ...
Vocee deve estar em boa forma, se voce executar e instalar todos esses programas.
4helpful
Maintenance call(m1) konica minolta 211
sintam se cumprimentados, estou com um problema na minha bizhub 211 ela pede para contactar tecnico (M1).como faco
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Boa tarde Tenho uma plotter t1110, quando ligada ele demora a carregar e quando carrega, da um erro 47:01 e pede para entrar em contrato com o support da HP
Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. 11_19_2011_4_07_20_am.jpg11_19_2011_4_07_49_am.jpg11_19_2011_4_08_22_am.jpgIf you feel this horrible work just replace star wheel unit..
Meu telefone perdeu todas as funções gostaria de rest, ou não sei se da pra formatar ou fazer o bot que nem o pc. Não sei mais que faço.
Alo grande.
Em primeiro lugar, eu so formatei ate agora Nokia 6600 e nokia N73 com os mesmos codigos.
Mas tu podes usar o mesmo codigo para alguns outros telemoveis.
Faca o seguinte Apos carregar bem o cellurar.
1 _ desliga o celular
2 _ volta a ligar o celular.( em seguida pressione logo nas seguintes teclas: Verde de atender, tecla 3, e tecla ASTERIX *. tudo ao mesmo tempo...) ate sair um sinal k seu celular esta ser formatado.
Se nao der, digite os seguintes codigos.. *#7780# ou *#7370#
Boa sorte
WHEN I TURN THE CAMERA ON, IT IS STUCK ON A BLUE SCREEN
a minha maquina não esta ligando, quando vou ligar ela aparece um codigo 5f08 e embaixo 5e02
Bonilla
Se a tensão das saídas estiverem abaixo de +5 volts então muito provavelmente é um resistor queimado! Tente descobbrir algum resistor queimado que conduz a tensão positiva de +5v sb da fonte(fio violeta) às saídas ps2 e usb, ou ligar um resistor de 10 ohms da saída da fonte(+5v sb) ao +5v(fio vermelho) das saídas usb frontais na placa ou em qualquer outro lugar disponível.A tensão baixa não permite que o teclado seja reconhecido no início.
Boa sorte
Moisés.
Eu queimei o resistor da minha placa quando conectei um maldito mouse novinho da clone!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
