Polycom HDX 9002 Logo
A
Anonymous Posted on Mar 20, 2014
Power supply cannot replace power supply
Why did my pc power supply shorts..everytime it replaces a fuse its short,,do i have to replace it a new power supply?
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
NEED A NEW UNIT OF POWER SUPPLY ATX-400W REV T1
At start up, no signal on monitor, computer shuts down.
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Have the HP-D3057F3H power supply - plug it in an the green light is flashing quickly - PC wont turn on - Is the power supply buggered or is it something else
Power supply light flashing green ,,, tried unplugging mother board still flashes green is it the power supply or the mother board?
3helpful
2answers
Power Supply Replacement
It never hurts to have a larger power supply, yes it have use 100watts more in a hour. But you should have better reliability with the 450W.
Mark
No pwr supply light on Pavillion desktop pc
Laptop will not power on
Shutdown the laptop
Unplug the power supply
Remove the battery
Plugin the power supply
Turn it on
If it works then the battery is shot and needs to be replaced
Still doesn't come on replace the power supply
If you replaced the power supply and it still doesn't turn on, then the you'll need to get it service as the motherboard would have to be replaced.
2answers
Power supply replacment
You should be able to replace the power supply. It is usually held in place by 4-6 screws. Unplug the cables on the motherboard and drives. Reconnect the new ones and away you go. A generic supply will be fine if it is of the correct physical size. Bring the old one with you when you go to get the new one.
Dan
Top Polycom Lands Phones Experts
k24674
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
