I recently bought an AOC E790Sw monitor. When I try to install the monitor driver using the method described in the manual, it gives a "a service installation in this inf is invalid" and there is a yellow exclamation mark in front of the monitor "AOC 1970w" in the device manager. I tried uninstalling and reinstalling, but the problem remains the same. I'm running windows xp pro. Thank you.
Go To Below official AOC Computer Problem Page For Your problem
http://www.aocmonitorap.com/root/anz/download_driver.php Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Technical Support
SOURCE: Acer AL1916W monitor
The AL1916W's native resolution is 1440 x 900. See if your display settings can produce that resolution.
SOURCE: Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
SOURCE: Can't change monitor display settings
no drivers are needed for monitor. Its the video card drivers that you should look for at the dell drivers and downloads website. make sure that you have the right driver installed so that you may be increase your screen resolution.You may also use your Dell Resource CD Drivers and utilities. Install the Resource cd, On the TOPICS dropdown box, select drivers,You'll know which drivers needs to be installed because they will have a check mark infront of the correct device driver. Clicke extract button after you have chosen the video driver. You may need to scroll down.Restart the computer.
SOURCE: unable to install AL1916w lcd driver in xp
i buyed the new al1916w lcd monitor ,i tried to install the driver for it.
i also downloaded the driver from acer site ,when i looked in device manager ,i found two plug and play monitor
plz check this link
<a href="http://imageshack.us"><img src="http://img151.imageshack.us/img151/2717/48550554nr5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
then i selected update driver from the right click and selected the folder wherethe driver was stored ,after searching windows cannot find the drivers.
i am sure that the folder has the driver downloaded from the site.
check this link
<a href="http://imageshack.us"><img src="http://img100.imageshack.us/img100/71/28697132zh8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
now how can i install the lcd monitor driver?
any other method?
SOURCE: cannot find drivers for product.
Hannspree said that there is no need for a separate driver for XP and suggested I check for an updated driver for my old NVIDIA Video card... That was the answer. I now get the full 1400X900 resolution.
