I NEED THE DRIVERS FOR TO INSTALLA MY ALPHA, IN TE LEXICON WEB THERE IS 2.7 VERSION. ANYBODY COULD HELP ME?
SOURCE: Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
SOURCE: my device manager doen't recognize the drivers i
Here is the support site for downloads:http://www.lexiconpro.com/product.php?id=7#downloads Hope this helps.
SOURCE: Lexicon Alpha got phantom?
The Lexicon Alpha does NOT have phantom power. The mic input expects a standard mic or a "self-powered" condensor mic. This means that you will neex external phantom power. There are power units available that use 9V batteries for this.
Dan
SOURCE: im having a problem with hearing my b-1 studio
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
SOURCE: hi, i have the Lexicon Alpha Personal Recording
Make sure you have NO antivirus/antispyware/antiadware or other resource hogging background programs running while processing the audio. These programs hog resources to the point that the buffering within the audio devices is overrun causing gaps.
