Instruction for accutime xoxo watch
This watch appears to be a battery operated model from the details I can find. Self Winding watches tend to be a LOT more expensive and usually a Big brand name! Assuming the Chronograph is designed to work the two buttons are usually 'Start/Stop', (top button) and 'Reset', (bottom button). Try this.
-Press the top button once. The smaller dials should start moving.
-Press the top button again. The smaller dials should stop moving.
-Press the bottom button once. The dials should reset to zero.
There is another function of the Reset button. You can 'Freeze' the chronograph display for things like lap times.
-Start the chronograph, (Top button once).
-Press the Reset button once, (Bottom button). The dials should stop. The chronograph is still running you have simply paused the display.
-Press the Reset button again. The dials should 'Jump' to the current position the timer is at.
-Press the Top button once to stop the chronograph.
*Note* Some of the cheaper watches simply have the dials and buttons for the look of it and don't actually work.
