if you r not getting display in monitor then first check in another monitor, if you assure that monitor id ok then replace the RAM else install a AGP card orvideo card for display,
I believe that is a No Post issue. Its not the hard drive because you said"and the HDD spins up, but it seems as though it doesn't reach POST"
or else you 'll be getting errors associated with the hard drive
There are some laptops even though it has a RAM NO POST issue will not beep " no display and no beeping at all "
For us to determine if this a Motherboard Issue we have to disconnect all parts that can be disconnected. Disconnect the hard drive, Memory (RAM), battery, if you have a Modem daugther card, Express card, PCMCIA Card.
Try Turning the computer on using the Power Adapter hooked up on the computer. If you are still getting issues Definetly that is a Motherboard have gone bad but we really need to check up other parts that are disconnected If Motherboard is good you will be getting video but it will stop on the POST screen and you might be hearing beep sounds as well. That means that the Motherboard is fine. Put the parts that are disconnected and clean the metal contacts as well one at a time and try to isolate at what part that is bad
You must have got a Cd along with the motherboard. Please use it to load display drivers. You can not change the display settings because your display drivers are missing. Install them and then the display will become alright.
if u have installed vga card remove that n try ur onboard ok after that also if that dint wor maybe ur motherboard, ram or ur prosser has burned are u getting any beep sound wen u onn ur pc if u get that surely ur ram has burned so u replace a new one if u get two ram in ur motherboard remove one n check ok
is this a brand new motherboard? do you have onboard graphics or a card? without testing i couldnt say for sure but it sounds like you are not getting power to your graphics on motherboard. this is usally a common issue for asus motherboards. not easy to fix. if your motherboard is new i suggest a replacement from the seller.
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
First Remove the Cmos Battery. Then remove external components from motherboard (like Ext .VGA, SOUND, Processor) Using Iso propile Alchol clean the motherboard. then after 1 hour you can give the connection. i will work. i used this method to solve more than 140 motherboard.
