Go to settings, support, software update. Make sure that your TV is connected to the internet. There may be a check box for automatic updates, check this for future. Then check update version. The pop up which follows will allow your tv to download and update the firmware. You should be able to install Netflix. ( Also in settings, options, make sure your service country setting is set to your cointry to USA
Pandigital recently uploaded a new firmware for the black Novel. It's dated 14 January.
I've downloaded and installed it. It's still based on v1.5 and still uses the B&N ebookstore, but on the plus side the new firmware turned the Novel from an ereader into a tablet.With this firmware you can now install apps without having to hack the Novel. (Of course, you could already do that with the CA firmware.)
Update: If you're looking for a the latest firmware update for this tablet, read this post. Much of this post is outdated.
Without any registration code, you should be able to download a firmware update or drivers for free. General web searches of your unit's model number can usually find these updates faster than browsing the manufacturer's website.
There is not usually much to go wrong with one of these units, and it would be rare that the driver software or firmware being out of date would cause the unit not to function at all, but rather, merely to function less well.
If your unit is inoperative, and external, the most likely problem is the power supply to the unit. Partial voltage can sometimes light the Power LED without actually providing enough current for the unit to operate. The unit should have power specs printed on the brick, and a replacement is probably available online, and possibly someplace like Radio Shack. It might not be worth the cost though, as prices of new units tend to drop faster than replacement part costs do.
These errors are almost always caused by outdated firmware. Print a configuration page and check the firmware version against this website . If your version is older than the one on HP's site then download the top option which is the easy install version and run it on your computer.
There are firmware updates available for this router available at the SMC Support Web Site.
Follow the link to "Firmware" under "Support" on the left-hand side. Apparently there are two different part numbers associated with the SMC2804WBR model number. Check the label on the router to determine which part number is yours.
Download the firmware update and apply the update according to the user manual, which is also available at the link above.
If this does not resolve the issue, then this router may be outdated and unable to support your iPod Touch.
Try to upgrade the firmware of the router. Firmware is the software of the router. Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router. Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router. On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in. Now you will need to reconfigure the router according to the Internet service provider.
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
