No Bluetooth peripheral device found on my Lenovo think pad z560
SOURCE: how to download bluetooth peripheral device
http://www.getpcmemory.com/drivers/download-acer-extensa-4620-4620z-4220-windows-xp-drivers/
above link will help you
SOURCE: could not found the bluetooth connection or device
Make sure you have every driver for your laptop loaded. Then let's suppose you want to connect your phone to the laptop bluetooth: Turn on the bluetooth in your mobile and make it visible to the other bluetooth device then only your handphone will detect the other bluetooth device and viceversa. Most of the recent notebooks are having bluetooth enabled but in some notebooks we need to turn on the bluetooth by using the buttons which indicated as bluetooth. Once you turn on then get into your computer running windows vista type this following command in the search box or in the run box "ncpa.cpl" it will take you to the network connection window [you can even use control panel option to reach the network options]. In that window where you find the bluetooth connection.Click the icon first and look it on the top of the window where you can see an option "Connect the the bluetooth"click it then you need to add the bluetooth device click add. It will find your hand phone then it will ask the passpharse key you can create one and then your handphone alert you to type the same key that u given in the notebook.Once it matched it will connect automatically. Later type bluetooth in the search option where you will get an option as Bluetooth(Transfer files wizard) . Click it then you receive or send the file via bluetooth between your notebook and handphone. Hope it helped.
SOURCE: problem in bluetooth.
may i get your help to send the the software bluetooth.because my laptop never have that software
SOURCE: my lenovo brand laptap needs bluetooth peripheral
You can download the drivers from Lenovo support site. Just check the back of your notebook for the serial number. Lenovo support downloads ask for that. Then, get the drivers. Turn on the bluetooth first.
Download the XP drivers for Windows XP. For Windows Vista and Windows 7, download the Vista drivers. Be sure to install the Chipset drivers first and then the sound drivers. Only then can you install bluetooth drivers properly.
SOURCE: Bluetooth problem in lenovo 3000 G430 laptop
i am using lenovo 3000 g430, and i am fall in problem about bluetooth,
i am already install xp and vista, but when i install the bluetooth driver
one warning message show me "bluetooth device not detected"
my bluetooth device switch is on but indicator led light still off,
please help me , how can i use bluetooth in this laptop.
Hi tanu jha, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is the laptop equipped with a Bluetooth radio?
