Razor E300 Scooter Logo
R
RROOAARR yay Posted on Mar 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E300 electric scooter battery,
Hi.I have an e300 electric scooter.I got 2 UPG Batteries for it.Two 12 volt 7ah batteries.They won't even last 10 minutes.My bad pair of batteries last twice as long.Do you know if RAZOR BRAND BATTERIES are better?Like do they work better and last longer??THANKS FOR YOUR HELP :)
Peter Anderson
Level 2:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Expert 31 Answers
  • Posted on Feb 27, 2015
Peter Anderson
Expert
Level 2:
Filmmaker:
New Friend:
Answers
31
Questions
0
Helped
31324
Points
259
I got mine from here and so far (9 months) they work well.
E300 Razor Electric Scooter Battery Set 2 batteries 12V 7 5Ah They are 7.5 AH and not genuine Razor batteries and they last so maybe your problem is not due to the batteries. You may try NJ Book Guy's suggestion.
ebike
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Oct 26, 2014
 ebike
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
38398
Points
45
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jun 08, 2009
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
ROB
  • 858 Answers
  • Posted on Jul 18, 2009
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Anonymous
  • Posted on Jul 19, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Anonymous
  • Posted on Apr 02, 2010
SOURCE: How do I test my batteries on my E225S Razor
Since the battery could put out 12v and still be bad your best bet would be to take the battery to Autozone or similar and have them do a load test (its free). This will let you know for sure if one or both of your batteries need to be replaced.
Anonymous
  • Posted on Sep 09, 2010
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
E300 razor scooter would run then stop then run then stop. Is it possible it is the batteries even if they read 12 volts on a meter?
Well how long between runs and stops? Batteries can be bad even with 12+ volts on a meter with no load. Is the on/off regular like the controller cycling, or irregular like a damaged wire? The hall sensor in your throttle could be causing it, if it's loose or not working properly. You can open the throttle with a socket and a screwdriver. Check all wiring, check the batteries under load. If you say more about the frequency and duration of the stops and run periods it would help.
2answers
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
3answers
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
What color wires connect toggle to ignition on boreen jia electric scotters?
black is negative, red is positive to controller, yellow is ignition on
Ezip 500 won't run : new batteries fully charged but it still shows low battery light...what else could be wrong
i'm having the same problem. checked fuses and both are good. going through the wiring harness to look for shorts. have a bad feeling the micro controller died, that is the little plastic box with metal fins on it under the seat post behind the batteries ******* to the frame. i can bypass the micro-controller and connect one 12 volt battery directly to motor and runs full speed. somehow it is wired with 2 - 12 volt batteries in series to give 24 volts and them the processor cuts back down to 12 volts to run the motor. not sure why this is engineered this way? still working the problem. what sucks so far is that the micro controller is encased in resin so it is virtually non repairable.
* Update added.
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harnedd to new harness to fit bike. Works great.
2helpful
I replaced new battery but still the scooter runs slow
The Razor E300 electric scooters are battery operated scooters and can run at 15 miles per hour. This is enough to produce the best fun for kids while on their free time. It's a quiet worker, and with that speed, you won't get scared of the child going too fast to be prone to accident. Yet, it is still good to take precautions. Let the kid wear a helmet, foremost, because this can protect the head should accidents happen.
Your scooter may need new batteries, or a controller. To check these components functionality you will need a volt meter. Check the current coming out of the batteries, check the current going into the batteries and both should read in the 12.5-14 volt range. If your charger, ore the charger connection is faulty you will need wiring, or a charge port. If your batteries are faulty, you will need batteries. Check your controller with a volt meter, or a test light to see that all connections are secure and the controller is functioning properly. If you need parts or repairs done, you can visit this Electric Scooters Parts Store Online with "Find a Repair Shop" feature.
I hope this helps; remember to rate this answer.
How to change battery in razor 300
I just did mine. You have to replace it with "2" 12volt 7ah batteries. They do cell a harness kit if you do not know how to soder it. I just spent 93.00 to have a motorcycle/off road shop do mine.
3helpful
Batteries die fast on my mobility scooter.
Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
Buy the biggest that will fit into the available space.
Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
Good luck. Neil.
I'm trying to figure out what kind of battery a schwinn electric scooter takes it is a s-180
Your scooter uses dual 12-volt, 10-amp hour sealed recyclable lead acid battery.
You may want to open below link to see some examples of batteries suitable to your scooter.
http://www.batteriesplus.com/products/78-0/6069-Electric-Bike-Scooter-Battery/252604-Schwinn/S180-Electric-Scooter/1.aspx
Regards,
Jeep Brainy
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
