I have lost the screws from the base of my Toshiba 42xv555d tv does any one know the size of these
To know more about this, you have to download the repair manual to this set. Its disassemble section will give you the details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Disassemble procedure to many popular TVs are given with illustrations. Hopes it will help you. Surf the site with patience.
SOURCE: I LOST THE SCREWS OF MY TABLE TOP STAND OF MY
Read the informations of those screws to tighten the tv and the base stand together.Read it in ur owner manual for those exactly screws sizes.Standard screws tvs sizes for a 46" are screw (M4 X L16).
SOURCE: base #72796233 for toshiba 23hlv85
Hi wsolem3
The base can be purchased here
http://www.encompassparts.com/products/?72796233
Let me know if I can assist further.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: What size bolts attach tv to stand for Toshiba 37"
You will use the bolts that you take out to remove the base from the tv.
SOURCE: I do not know the
You should be able to buy a universal remote to fix this problem.
Can you get into your main menu.? If yes, try reseting to factory default. If asked a pass, try 0000.this should do the trick.
Hope this helps.
SOURCE: I am trying to hang
Sounds like you are attempting to screw in the wrong length of bolt. Tv's generally use a shorter bolt and you should NOT attempt to screw it in any more than it will physically go - remember, there is sensitive electronics behind those holes that may break when you screw something in too far.
Just screw them in as far as they will go and leave it at that. Alternatively, go down to your local hardware store and find a bolt of the same size but shorter.
