I have rest my phone 3 times and I still have the issue that whenever I pick up the receiver/handset line 1 lights up blue and then line 2 lights up red. How do I get it to where only the line I select works?
SOURCE: RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
SOURCE: Need Help to Program my Phone Please
Go to Line Priority and set Line 2 as Priority Line. It should work.
SOURCE: 2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
SOURCE: Have an RCA executive series. the light for the
I have an RCA Executive Line 4-line phone. I was away for a week, and came back to find the speakerphone when I dial out is significantly muffled on some of the lines (people that I am calling complain of noise on the line). If I take it off speaker, the quality on the handpiece is normal. First, I thought it was the batteries, so I replaced them. Didn't change. Is there a reset? Is the phone (base) after less than 1 year defective?
SOURCE: so much static I can not hear properly
The line that stays lit for line 2 is just the way it is.. not a problem. If you only have one phone line and a two line phone you will always have the one (non working line 2 ) lit.
Have you replaced the cord to the handset? Many times it is a bad cord that causes static.
Sorry... I reset my phone three times not rest my phone. Lol
