I have a planae pdp42v5. turn on pwr and green light on for 5 sec then flashes. diode 16 on logic board flashes. p/s voltages 190, 65, 30, 12, 5 vdc all check good. replaced logic board no joy, same problem. no schematics or trouble tree available. can tou offer any help
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
SOURCE: six flashes on self-diagnosis
I have the same problem too. I have known that panels with this problem (6 blinks at startup) are replaced in US for free. Unfortunally I'm in Russia and nobody but myself can help. Please let me know if you have a solution for this.
Thanks.
SOURCE: Conwa 42" PDP Plasma TV with Orion PCBs
I have one and have been told the main board is not working.
Cant get parts. Do you want to sell your main board.
SOURCE: Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
SOURCE: Sanyou DP26746 LCD TV Has sound, No picture, Has backlights, LCD is active
It sounds that the main digital board to your TV has damaged. But, before make it confirm, a through check should be done. Contact any experienced service technician for help. The work is skilled one, that a user cannot do it with ease.
SOURCE: no picture but sound
Here's what you need:
1) General guide - very similar TV, same main issues and troubleshooting process:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
2) Most common repair for the pdp42V5 chassis:
http://www.coppelltvrepair.com/p/227/viore-pdp42v18ha-ysus-6871qyh053b-repair-service
Hope this helps!
