SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
SOURCE: Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
SOURCE: Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
SOURCE: Whining sound from motor on Frigidaire upright freezer
Hi: It sounds like you bought a frost free freezer as it has a fan. The fan will come on to circulate the air. It will not necessarly run continuosly. The noise is most likely coming from the fan. I sold Frigidaire freezers for years and they are noisy compared to a refridgerator. If you think it is louder than it was when you bought it, I would replace the circulating fan. Also look at the back wall for frost as it could be a bad defrost heater blocking it with ice. Most likely just the fan though. Since it's in a detached garage,and you won't have to put up with the noise inside your house, it could run a while before failing. The fact it's getting cold is a very good sign.Also as you asked 2'nd, a freezer is ok in an unheated garage. Don't put a refrigerator in there. Unless It is a Whirlpoll Gladiator that is designed for such applications. Use www.searspartsdirect.com to find out where the fan is if you feel it is necessary to replace it. Its not a tough job if you are handy. Their shipping is expensive so you might want to buy it locally.
SOURCE: FRIGIDAIRE UPRIGHT FREEZER COMPRESSOR VERY HOT
Well I finally found the screws for the front grill. The compressor started cooling off once the seal was put back in place. So I'm going to give that a day or so. Still did not find the coils I'm assuming that they are in the sides. One thing I do know for sure, is that I'm putting you guys in my favorites. I educated myself so much from your website. I'm not sure I ever had a problem except the seal. I don't have the original motor to check but I'm working on getting it back. If I would have found this website before the tech I would have saved $150.00. Thank you so much.
