Computers & Internet Logo
A
Anonymous Posted on Mar 18, 2014
Epson stylus cx3400 - Epson Computers & Internet
L Pfaff
Level 3:
Top Expert:
  • Epson Master 11,573 Answers
  • Posted on Aug 25, 2016
L Pfaff
Epson Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585447
Points
181713
tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
tip
Reset Epson Color Printer Counter
Many Epson Printers that reach an End of Life counter number will lock your printer down and force you to contact a Service Center.
However, this is really not necessary in all cases. If your printer is still working fine for you but the counter has locked your printer:
To download this free utility program read the agreement and then download.
Follow all instructions for download, install and usage.
End user agreement
1) This software is provided "as is" without any express or implied warranty of any kind including, without
limitation, warranties of merchantability, non-infringement or fitness for any particular purpose.
2) You are liable for all risks in relation to the quality or performance of this software. In no event shall SSC Localization Group or personally, author of this software, be liable for any damages whatsoever caused to you or the third party arising out of the use or inability to use this software. Damages include general damages, special damages, accidental damages or consequential damages (including, without limitation, loss of data or accuracy or unfitting interface for other programs, or problems with peripheral equipment).
2) You understand the risk of whole head or individual nozzles clogging in case of tardy replacing of empty cartridges, as well as risk of using hot swapping function (this include frequently cartridges replacement, or wrong deblocking of parking head on some models). You understand, that resetting the ink level counters or using ink freezer function implies responsibility to carefully watch ink levels in all cartridges and timely (as soon as You see any raw white bands, even in one color) replace cartridge.
I agree with all above statements and want to download software (v4.30)
Supported Models:
Model
Epson Stylus C50
Epson Stylus C60
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson PictureMate
Epson Stylus Photo
Cx3400 manual
try ebay or ask the 2carpros online
Matching amps for cx3400 crossover
You can use any amp with a passive crossover.
1helpful
2answers
I thave lost my software cd and i am looking for
www.epson.com.ph/epson/drivers/driver_download.htm?.
or
www.liutilities.com/device-driver/epson-stylus-cx3200
www.driverfiles.net/.../Epson/EPSON-Stylus.../download/page,sh,29225,154,12,.html -
2helpful
2answers
Need xp 64 bit driver for Epson Stylus CX7800 all in one printer
Thank you for choosing epson.
Note that you have to uninstall the existing epson scan software and epson printer software on your computer first.
Log on to support.epson.com to get the proper driver for your printer.
These are the drivers that you need to install:
TWAIN Driver and EPSON Scan Utility v2.68A
epson11620.exe
Printer Driver v6.51
epson12767.exe
You can also click on the link below:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58773&prodoid=56291070&infoType=Downloads&platform=Windows
Please inform me if you need further assistance.
Sherlyn C.
Top Epson Computers & Internet Experts
Rob Hill
Rob Hill
Ngoro
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
