Please check your breaking system to see if it needs to be repaired or have some pieces replaced in order to stop the issue from occurring when your motorcycle slows down.
Is the belt correctly tensioned. Do you feel that the belt is slipping. Does the motor noise change and slow down, or does the motor sound the same? If it slows, then the motor is failing, or you have exceeded it's weight capacity. If the motor remains at the same speed, then the belt is slipping with you as the resistance on it.
LUBe the deck belt inmediately in according with the instruction manual maintenance, you have some deck belt worn. 2) Inspect the drive belt for replace.
RUN THE SOFTWARE CALIBRATION for diagnose and troubleshooting.
have you checked 1.to make sure it's plugged into the wall outlet good? make sure the power & foot pedal are connected correctly to the machine? 2.does the motor smell in any way? when was the last time it was serviced?
The walking belt slows when walked on the walking belt maybe overtightened, treadmill performance may decrease and the walking belt may become damaged or the opposite the drive and /or running belt may need tightening. Last thing would be that the belt needs lubrication to be applied between belt and deck.
Good day!Try some tests..like replacing power cord,printer cable and reinstall driver..if nothing happens..then try to see if the belt on the assembly is already weak..cause it can slow down your printing..or the film like inside is dirty..if you can open it much better..i
