Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
SOURCE: my att remote control for my uverse did not come with a manuel
Here is the manual for the remote and the codes are there also.
http://helpme.att.net/pdf/uverse/remote_control_user_guide.pdf
Good luck and Please rate FixYa!
SOURCE: L32hd41 code for uverse
I have the same TV. I called RCA and they said the remote is not 'code compatible' and that I should check back with the website in the future. I think a learning remote is the only option at this point. Maybe a Logitech Harmony?
SOURCE: need remote code for model L32HD41 RCA TV.
A learning remote found at Target works great! It is a universal GE 5 device remote control (model 24950) - and the best thing is that it is under $13! It can only be purchased in the store, but if you go on the Target site, you can check if your local Target has them available.
SOURCE: I need the code to att uverse cable box for Philips univ remote
I have the same exact problem, did you ever find the answer?
SOURCE: i am trying to program my vizio remote to work
Vizio
Television
1343, 1018, 1004, 0178, 0502, 0627, 1756, 1758, 0128, 0117, 1017, 1078, 0030, 0056
VIZIO
HDTV
1004
If your tv is HD mute wont work.
This is for programming the uverse remote to the vizo tv. From my understanding the uverse box doesn't have a code.
