Question about Sony Cameras
Sony receiver stede485 display shows "protect" ?
What does protect mean and how do I fix
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
There's apparently a short in the speaker wire.
Posted on Mar 18, 2014
SOURCE:
Sony receiver stR se-501 found fuse burned after replaced turned on the flashing massage PROTECT come on . Did I miss anything?
Protect typically means that the fuse blew because something in your receiver went bad. It's now protecting your speakers from that badness. You need to get the receiver fixed or replaced.
Jun 16, 2015 | Sony Str-Se501 Stereo Receivers
Display showing PROTECTION
if this is a sony receiver, that usually means there is a blown amp channel that will need to be repaired before the unit will power up correctly.
Mar 31, 2015 | Audio Players & Recorders
The display say "PROTECT" whenever you turn it on.
your sony channels receiver it says protect bec ther is to much power on the speakers to fix it get les powered speakers then it will work
Jul 26, 2010 | Sony STR-DE345 Receiver
I have the code pcm 48 showing up on the display and dont no what it means or how to fix help please
PCM 48 means pulse code modulation at 48kHz. Your receiver is decoding digital information and displaying what format it is, and it's frequency. That is normal.
Dec 25, 2009 | Sony STR-DG810
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
"Protect" Flashing
In all likelyhood, one or more output transistors have failed. Please confirm your model as STR-DE335 and I'll post the probable parts that need to be checked.
Dan
Jan 22, 2009 | Sony STR-DE335 Receiver
Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
SONY STR-DE675 RECEIVER
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
Protect?
Overload protection circuit kicked in. Check all your wires (speakers,input,output cables), There is a short somewhere and lets hope it's not In the receiver.
Jul 12, 2007 | Sony STR-DE197 Receiver
Cameras Logo
13 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
