SOURCE: replacement console
Unplug unit then remove the upper console, their are 4 allen bolts holding it udder the console their is a panel held by 4 phillips head screws also remove them . Look inside the compartment and their should be two connections, disconnect them. Now pull console off its tower. Lay it upside down on a thick towel remove all phillip head screws you'll notice where the emergency stop button is connected. I have found that this connection 7 out of 10 times is causing the problem. Buy cutting the lead connector stripping the wires and soldering back on the male connection will resolve the problem. If not their is a emergency stop kit may be purchased and replace. The only other thing that may cause the problem is the function key pad itself. Try the first solution if your not good in soldiering go to a computer shop , t v shop they should be able to do this very quickly for while your at let the check the switch itself.
Testimonial: "This guy really does know his stuff. I am very pleased I was able to fix the treadmill with absolutely no expense. I simply followed the clear instructions and the machine was up and running in an hour. I would rate this expert 10/10 but actually he warrants 11! maxtreadmill yo da man !"
SOURCE: Life Fitness treadmill model 9500HR. After
try to reset the treadmill by following these steps :
1•
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
•2
Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
•3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
•4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
SOURCE: life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
